Out of interest, how are you controlling the Gimson actuator? I'm wanting to purchase one for a simple lifter for my first FW.
I was thinking I could use something like a botbitz ESCheap25 because this actuator uses 27A at stall (which I don't think it'd come near) and it'd give fairly precise control.
Yeah, I asked Ewan Gimson what he would recommend to control one of his GLA-S actuators and he recommended that too. Did he also recommend it to you? xD
I'll probably go ahead and try grab myself one of those too. Did you consider anything else, because as far as I'm aware, the wasp is just a simple on/off switch, whereas an ESC (like a botbitz ESCheap85) would offer more control?
The wasp has the ability to add limit switches, otherwise my actuator try's ripping itself to bits it still has lots of control. as you want the actuator to run flat out when moving rather than comtrolling it's speed.
I have not posted here for a bit, I've been distracted by evolving my design, and building it . The same ideas of interchangeable weapons. After watching the likes of 720, NST i think this new version should be more up to the mark strength wise.
I am at the moment sourcing a Spektrum radio set, then we should have some test videos.
So here is an update, you may well think is he actually going to finish a robot. I have been on a continuous process of designing, testing and redesigning. Along with watching a lot of Youtube videos. I am still taken with the drill idea, but have worried a lot about armour toughness. Robots so far that have sent me back to the drawing board are 720 and Cobolt! Recently another person posted about the gauge of Calor gas containers. This inspired my latest shed time here are the results. Needless to say I'm very pleased with the results.
The weak point of those ground skimming wedges will be the bolt connection. I would recommend welding them to the axle if possible along with the bolt?
