Sabretooth Reborn as a Feather
  • #31
    Re: Sabretooth Reborn as a Feather
    4 wheel drive, with one motor each side offset
    • #32
      Looks really interesting
      • #33
        Aluminium, hdpe, drill Weapon(posh), ordered
        after a supplier of hardox
        and waiting for Ewan to get some actuators in stock
        then i can start the build.
        • #34
          Is it the 100mm's you're after? They should hopefully be back in stock in 10 days, along with 150mm's and 200mm's. Looking forward to seeing how the drill weapon works out, done effectively I'm sure one could eat through a few of the plastic machines.
          • #35
            Hi I was after the 100mm's but now you have mentioned others, I maybe interested in them, could i get the specs for the others i.e. length when retracted and when fully extended, I imagine widths etc will be the same as the others.
            • #36
              The diagram here should help http://www.gimsonrobotics.co.uk/GLA_lin ... tions.html
              • #37
                Thank you Ewan, does this diagram just show the 50mm stroke or the 100 as well, i maybe being thick . are the others of a similar size, I reckon i might like the 200 one.
                I'm after a TX RX system, that two people can use, pistol grip for drive, hopefully plugged into a conventional stick for the weapons, any ideas?
                the TX RX is also posted in the pistol grip thread, repeated here as its part of the construction diary
                • #38
                  It applies to all of them, just replace 'S' with the stroke length. the 150mm and 200mm are the same style as well.
                  Not entirely sure about combining two transmitters, not something I've done before but I'm sure there'll be someone else on the forum who's attempted it, good luck!
                  • #39
                    thank you
                    • #40
                      As far as I'm aware, Dave Moulds runs his featherweight 360 with two transmitters. He uses a pistol-grip for the drive and has a DX7 (I think) connected via a lead with Kenny controlling the disc and self-righting arm. I'm sure if he sees this he'll provide more informative comments, but that's as much as I can offer I'm afraid.
                      • #41
                        Well thats exactly what I want
                        • #42
                          then do it
                          a very different robot, very interesting indeed!
                          • #43
                            developing the interchangeable weapons, the drill i did today, a lot of dremmel work cutting down the body, the disc will be machined soon.
                            • #44
                              First picture looks like a mini-Warhead, minus the tail
                              Second picture puts the size of the robot into perspective, it looks tiny!
                              But all in all it's still the most interesting looking feather I've ever seen and can't wait to see how it progresses.
                              • #45
                                Love the tilted disc concept, as Gary said very evocative of Warhead. Are you planning on running the claws with steel cable so that as the bottom section moves the second outer section simultaneously unfurls? That's the first idea that comes to my mind
