New FW- doorstop
  • #46
    Re: New FW- doorstop
    Do the replicas run ok on 22v? Would they be ok running in 24v as a spinner motor?
    • #47
      yeah, had no issues. get a little warm but thats it. I'd say give it a go as they are only £12 delivered on ebay! only thing might be that they have less torque than the real ones so you may have to reflect this in the spinner drive ratio.
      • #48
        What gears did you use?
        • #49
          Modified 90t mod 1 spur and 12t pinion gears. All from technobots
          • #50
            Need a little advice if possible. I currently run a 2wd replica speed 900 wedge rambot, which is generally built from HDPE, but I'm flirting with the idea of resurrecting my 4wd four motor 22.2v rambot built entirely of 5mm steel. Not too sure whether to stick with HDPE speed 900 bot or go for a 4wd drill steel bot? Any guidance would be much appreciated!
            Cheers
            Dan
            • #51
              i used this website to calculate the weight of the the Armour for my 4wd that got 8mm steel round the sides but i had to use 3mm on the base and aluminium for the top plate to keep it in weight, and i just weighed the wheels motors etc and its about 12kg without the wepons
              http://www.matweb.com/tools/weightcalculator.aspx
              it was drill powered not speed 900
              • #52
                Size of wheels? 100mm?
                • #53
                  120mm diameter with bicycle tread
                  • #54
                    I'd be amazed if normal drills would handle that. Ours destroy themselves with smaller wheels and lower voltage...
                    • #55
                      Very fast machine then.
                      Unless you got a strange set Speed 900 replica's. What size of axle did they have?
                      • #56
                        Sorry, my fault! The replica speed 900 bot runs 120mm wheels on a 12mm axle. The drill bot would use 75mm robo challenge wheels
                        • #57
                          I ment, what axle does the replica 900 have. There are 3 major types.
                          5mm, fast runners, ment for applications as battery-leafblowers and such.
                          6mm, speed 900 size.
                          6.35 - 1/4 Ment for car applications.
                          • #58
                            5mm output shaft. These are the replicas from ebay
                            • #59
                              Fast runners then. 12K rpm @12V
                              @22.2V those want to run 22.2K rpm. With a gearratio of 7.5-1 the theoretical topspeed should be 71km/h, given time.
                              Unfortunatly, it will be something about 35 km/u, and the motors will run half speed, drawing more amps. Don't close of the vent holes, and maybe adding a small fan to keep the air flowing trough the motors at all times.
                              • #60
                                These are the ones some others and I are using:
                                http://www.ebay.co.uk/itm/12-v-ELECTRIC ... 45f7de0c88
                                I'm just unsure which direction to take?!
