Team Enigma build diary
  • #31
    Re: Team Enigma build diary
    Yeah, spose you could say that.
    • #32
      Well 1 1/2 working ones and two that are just static, but still
      • #33
        How's work going on reaper then?
        • #34
          Ok, it's at the de-crapping stage right now
          • #35
            Hope everything goes well with that.
            • #36
              Started work on Mr Nasty and X-Terminator today. Mr Nasty needs the batteries replacing, but luckily the motors still work. Everything else on Mr Nasty works, but X-t needs to have the motors and batteries put in, and everything needs to be wired up.
              • #37
                Both are looking great, cant wait to have some fun! X-t will keep you busy wont it? lol
                • #38
                  Thanks and yeah, X-t's likely too keep me busy for a long time, hopefully I'll get everything running eventually.
                  • #39
                    Switched the batterys on Mr Nasty over today, and it now works well. Mr Nasty is now fully working, just got a small amount of damage on SA from the event in Portsmouth to fix, X-t will need a lot of work, but hope to get it running soon.
                    • #40
                      had the hawkers been left charged, if so you might be able to bring them back abit by putting a few good cycles through them? If they were flat then you won't be able to.
                      • #41
                        Yeah, they where fully charged after they where last used. I got two sets with Mr Nasty, the ones that where plugged in inside it when I got it don't work, but the other set worked straight away, and didn't need to be charged even though they'd been left for many years, not sure why, but it made it easier for me
                        • #42
                          I have one question, is Mr Nasty on 40MHz ?
                          • #43
                            not for much longer, i think im buying the radiogear
                            • #44
                              Yeah, you can buy the 40mhz radio gear if you want Harry, I'm going to convert Mr Nasty to 2.4 ghz soon.
                              • #45
                                any more news on these guys?
                                and have you finally got any videos of any of yours yet?!?!?!
