Reviving this old thread as bot building has become of interest for me again, esp with the return of robot wars. Bot building is kinda dead in sweden, but hopefully can get back on its feet with some aid from the television.
Anyhow I've made some progress on my first beetle.I did learn some mistakes from my Ant which i tried getting to be perfect even though it was my first bot. Hence i dialed down and made this a bit less complicated and not having to scrap and rebuild it over and over.
The design i wanted was to hace protected wheels, invertible and somewhat flat wedge.
I have the regular 1000rpm motors, 3s 850mah Lipo, 40mm wheels and an old sabretooth 2x10 so i chuck it in there. 5mm hpde sides and 2mm alu for baseplate and bulkheads. everything hold together using m3 bolds and lokc nuts. its hack sawed and hand drilled so I know its not straight and clean
My ambition was to attach 15mm hdpe sides, some 2mm angled mild steel at the back (hard time getting hold of hardox cutoffs here) and probably some mild steel wedge at the front. along with either hdpe or polycarb top as iI have that lying around.
at 760g here's where it is atm:
