Cicatrix Build Diary
    Re: Cicatrix Build Diary
    Gary just mentioned that on Facebook actually . It could be done, would just need to wait until my cousin wasn't looking and steal Daiske's radio gear and batteries and we're good to go. A cluster rambot would be ineffective though would it not?
    I also discovered today that one of the wheels when its put under any weight, the grinding noise it makes is making me think grub screws, but that'll be for another day.
      It would be cool.
      Call one Potato and the other Po-tah-to :P
        Fighting as a cluster may come in useful at some point, maybe try it for a laugh sometime. If for some reason I have Cicatrix and Daiske both in bits at the same place then i'll whack the necessary bits into the front pod of Cicatrix and try it out, will put a video of it on here if I ever do.
        I would do it tomorrow, but it takes so long as so much effort to take those M10 bolts out, need to pretty much disassemble the whole front end to do it. Actually, maybe when i'm taking out all the ESC's to replace them with the XXL and neatening up all the wiring i'll give it a go, should be funny.
          Originally posted by Leonardomayo
          It would be cool.
          Actually, let's call the whole thing off!
          You say a cluster ram bot would be ineffective, so why not give them weapons? Kaizer comes in at about 7kg and it has a weapon. Survived Buzz bar too.
            Because its not a clusterbot The front section could and will have a weapon yes, but to give the rear pod that houses all the important things a weapon would compromise the whole robot and its also not really big enough.
            Cicatrix did survive Buzzbar, it was working the same amount before as it was after
              A couple of CADs to show what the plans are:
              It's quite a cool way of working. The idea of interchangeability (is that even a word?!) certainly isn't new but this is probably the first machine in a while to actively do it in the featherweight class. Thankfully the first phase didn't fail at the NEC (impressive, considering I built it ) so will be good to see how it performs with the different setups.
                I really should have posted the CADs on here shouldn't I... ahh well, they're here now
                Phase one was a success really, even if it looked like a failure the concept didn't fail, just my driving and inability to listen to simple instruction .
                Speaking of that, where can I get more of those screws Jamie? They're really soft, burst the head on a few of them and one of them I snapped in half right across the thread. Hopefully with that new drill bit i'll take care of new ones a bit better though.
                • #23
                  I got them from Technobots:
                  http://www.technobotsonline.com/csk-hea ... 32995.html
                  Pretty cheap, you can get almost 200 for £5. But they are quite soft and will dislike you if you try to attack them with anything other than a pozi-3 bit. I'm looking at getting the same size but with socket heads for the Drumroll II chassis rebuild and for continuing the work on Carcinus.
                  Found 100 on eBay for £9 so a bit more expensive but they're a higher grade so should be a bit tougher:
                  http://cgi.ebay.co.uk/M6-X-30-COUNTERSU ... 1047wt_905
                  • #24
                    i bought a bunch of hex headed countersunk screws for the comp to replace the philips headed ones. Far better and far more difficult to chew the head. Get em cheap off of ebay.
                    o and throw a hex key in a cordless drill and you can take them out in seconds
                    • #25
                      Haven't updated in a while but will try to keep it brief.
                      Cicatrix now has its XXL in and will be testing that over the next few days, thats probably as far as I will go with that before RL Edinburgh but hopefully it will add a lot in terms of controllability and reliability compared to the mix of Scorpion and Electronize ESC I had running at the UK Champs
                      Decided to create a Daiske II, which had it first test today, possibly will get that running for Edinburgh. Was only running it at 7v, but should be on around 3 times that at Edinburgh and probably on bigger wheels. Took a wee video of it earlier.
                      http://s1214.photobucket.com/albums/cc4 ... -17-29.mp4
                      Looking forward to Edinburgh anyway and will hopefully be running 2 machines that are both useful and don't go on fire regularly
                      • #26
                        very nice
                        • #27
                          Would I kill that Scorpion XL if I ran those motors at 24v do you think?
                          • #28
                            whats the rating on the xl i cant remember
                            i think you have to clip a small connection if you run over 16.8v btw
                            • #29
                              Crap, just remembered you asked me that on Facebook and I completely forgot to reply
                              I don't think you'd kill the Scorpion XL, mainly because the speedo has current limiting built in. With my XL in Drumroll II, whenever I slammed the stick full forwards, the wheels would spin almost to full speed but then cut out, which I believe was the current limiting kicking in temporarily; I'd have to either then bring the stick back a little or ramp the speed up gradually to get around the issue (never was much of an issue in battle though).
                              So if you were to run the golds on 24V and they ended up drawing too much current, the motors would (should!) just cut out to protect the speedo.
                              One thing to possibly watch out for though is that the Scorpion's max input voltage is 28V, but a fully-charged 24V battery pack will be nearer to the 30V mark, so that might cause an issue. A similar thing happened to Gary using the Sabretooth. He was running two 18V drill motors at 24V and let the magic smoke out of two units before reverting to Electronizes. The increased current draw from the motors as a result of overvolting, as well as the high voltage of a fully-charged 24V pack were most likely the reasons for the failures.
                              • #30
                                I believe it is 12.5A per channel and the XXL is double that.
                                Yeah you do, I had it clipped when it was in Cicatrix at 19.2v then reconnected it for that test.
                                Haha no worries Jamie, I could try that combo I have set up in the video with the batteries from Cicatrix then, fully charged they are around 22.5v, and if it runs ok on that then I could just use the same type of batteries in both robots, which would be great.
