Continuing the trend of starting projects and then starting yet more before the first is finished: here's another beetleweight. It's a great class to build in, especially with the range of RC/model components available relatively cheaply. I don't expect this one to do much but fail spectacularly, but it's an experimental concept. Inspiration comes from 'Gene' on the RFL forum, a while back he experimented with a kinetic axe (himself possibly influenced by the likes of Team Whyachi's Warrior), which looked like so:
I don't think it actually ended up in an operational machine but the concept was sound in my eyes (and pretty brilliant in that that 'trigger' for the axe is simply braking the flywheel motor). So I drew:
Key differences with this idea are a horizontal flywheel and cable-drive to the axe arm (notice the 'cam' around which this cable would run). The bottom bits may look like a bit of a scramble - that's just me trying to work out how to fit all the bearings & firing mechanism into the height of the thing. A key issue is how to transfer a ~6000rpm disk into a sudden actuation, this will hopefully be done with a chunk of steel hitting another chunk of steel, without either breaking?...
Continuing the trend of being a bit weird, different and likely to break I've decided to use car-steering also (a'la Killerhurtz of old/The Judge). At the pile'o'parts stage at the moment, don't expect this to be finished before the end of summer! (along with the featherweight & electric scooter rebuild...):
Thoughts?
Thoughts?
