Re: Team Invade's Build Diary
Considering the last feather we built was Explosion back in late 2007/early 2008, and we've still got all the parts for the new Invasion which never happened, I thought it was about time we made a new one.
However, this time my Dad can't be bothered, excuse was something to do with him being too busy with one heavy and two feathers to maintain, so this one I'm building by myself.
So I've already got:
2x Feather Gold motors
2x 4Ah lipos (one spare)
1x Sidewinder
3x RoboChallenge wheels (we've lost one somehow)
Various amounts of HDPE
Various amounts of Hardox
But we've already got a pusher, so I'm going to order a brushless setup and try a spinner this time
So, first progress:
The first thing I did was cut the 20mm bulkhead (last weekend). Back then it was going to be a drum spinner (hence why it is so long), but I've changed plan to a vertical so they'll be shortened, but I'm leaving them for now as I'll probably have changed my mind again by next weekend. I had my first go on the lathe this weekend and made the aluminium spacers, turned down the wheel and pulley and bolted them together. The outer HDPE is only 10mm but it'll be wrapped by Hardox when finished so it should be fine.
Did a quick test by plugging it into the lipo and all seemed fine. It's only running on 5S so I think the 3:1 reduction should be fine.
There are a few things left to do such as shortening the axle, shortening the screws that fasten in the motor and adding some bearings, but that shouldn't take too long so I'm hoping to start the next one next weekend
1x Sidewinder
So, first progress:
), though I have seen several instances of nylon cracking in combat.
