[attachment=1:1piieswr]1.jpg[/attachment:1piieswr]
[attachment=0:1piieswr]2.jpg[/attachment:1piieswr]
Baseplate cut and components placed where they will be mounted, not yet mounted
Baseplate weighs 8.8kg
looking good. The only thing i will mention, if your planning on using the bearings for the flipper, as they are cast the do have a tend to crack the casings.
Id second that, we use that type of bearing at work on loads of area's of production... when the shafts sieze up on them and the bearing's carnt be removed easily, a good hit with a hammer and the castings snap in two...
One hit from THZ or Thor on the top of the arm and it could be game over...
You might be better of mounting a block on your back plate with brass bushings going through it... theres no real need to mount the pivot on bearings...
Apart from that it looks really good. Possible new champion in the making
