Re: Team Avenger build diary
most probably, best thing is to measure the voltage with nothing running, then try and measure the voltage when under load (can be difficult to do safely). Don't know what charger your using, but might be worth getting a 12v low current (couple of amps) and charging each battery seperatly, make sure they all get a full charge.
