Team Avenger build diary
  • #46
    Re: Team Avenger build diary
    its only a basic ram bot, but do ya think you could run 2 drill motors off some 30a esc's?
    • #47
      Probably, At the champs I ran the drills off 2 15A Electronize and a Scorpion XL which I think is 12.5A per channel, and they didn't blow (well, not because of the motors anyway...) so I would guess they would be ok.
      • #48
        mabey even 2 15a with 25a fuses
        thats what jamie does for drumroll running it al 19.2v
        • #49
          Jamie uses a Scorpion XL in Drumroll II.
          • #50
            he used 15a in drumroll 1
            • #51
              I'll take your word on that, but I don't know. In answer to your question though, if you're going with a similar setup to what Jamie used (15a electronize and drill motor on 19.2v) and what Cicaxtrix rear pod used to use then it worked for that, so I assume it will work for you. One of my electronizes did go on fire, and the other died (surprisingly the one that went on fire survived) but they did work. The Scorpion was far easier to work with I found.
              • #52
                with 30a driving 2 motors at 12v i dont think we will have that problem
                • #53
                  You will if you do what I did and connect the BEC to a live wire
                  • #54
                    ah, that would cause some MASSIVE problems
                    • #55
                      Just a small fire after a collision with Tiny Toon, but the speedo survived.
                      • #56
                        lian came over this weekend and we didnt get much robot building done, too busy riding down hills very quick on bikes
                        first, i couldnt weld my nuts to the plates i needed too use for ReAvenger (nuts and bolts style nuts, not the other kind ) since i found they were ali, not steel and trying to weld the two together is impossible!!!!!!!!!!! so i need 12 new STEEL nuts and bolts
                        Although, we did finally decide on a design for lian's new bot, but ill leave him to do the talking on that
                        And a steel company from around here are amazing and let my rumage through the skip of theirs and in doing so we found an old push lawnmower with cast iron body shell, so that is very helpfull
                        • #57
                          [quote=mattsdragons]Although, we did finally decide on a design for lian's new bot, but ill leave him to do the talking on that quote]
                          I'll take over here Matt thank you
                          The current concept we have for Avengeress is to go for a Maelstrom shaped bot, no flipper, just a wedge. I also have
                          a flipper bot idea, but it has to wait
                          • #58
                            got nearly all the wiring done today and by next week i hope me relay will be here. if it it then in the next 2-3 weeks, i should have something i can drive and make my actuator move, but designing the claws will have to come later
                            • #59
                              Update time.
                              Avengeress is gonna have a repaint. Black and Orange. Hopefully get something done with it
                              • #60
                                another update for me
                                got my drive systme working... sort of. the motors are turing but only one will respond to the RC gear
                                also, i aint figured out which channel is my actuator yet so that will take some time aswell
                                give me a week or 2, 3 at the most and you will see a robot back in my ownership
