It annoys me that most of the questions you're asking you have asked atleast once before! And most of this info can be obtained by looking through the heavyweights section!
i got bored so i started making a new parts list and if anyone has opinions on it then say. i hardly call that repeating, the old one was a bit vague so i needed to make a more refined one
100mm bore 120mm - 0.95l, i was more thinking 75mm bore 200mm stroke modified hydraulic cylinder. nimhs i'd say 10ah+ though you might get away with less depends on the discharge rates that the cells have.
You'll rip the chassis to pit with a ram that size, and no point if your only having one burkert feeding it. See if you can find out what size it had in before and aim around that, i would guess something like a 63mm bore 200mm stroke (same as Merlins). Why see what weight you have available and just use some cheap SLA's.
