got the drills and i'm planning on modifying them on Tuesday i'm also hopefully getting a radio set next week
Flip-Side's build diary
Re: Flip-Side's build diary
Yeah the trick i've found out is that it is so much easier to get the chuck off before getting the motor setup out of the drill. Still doable but with more hassle to have the chuck on. But nowadays i could slaughter them in my sleep :P
I read stories about that, I tested all the batteries before dismantling the drills. If it gets to the stage that you need them for use in your robot once its built there will probably be someone on here who has them going spare.
So it came like that? A bit unscrewed?
Also, is this with the grub screws in? If so it could be that isn't not working properly because the grub screws are too tight. Did you put those rings in that that guide I sent you suggests? Because if you're using grub screws you don't need to, but it would prevent you from tightening those screws if the rings are too big.
