Fractal [beetleweight]
    Re: Fractal [beetleweight]
    Also wish I had the equipment to bend metal like that >.<
      Its a good design all round, the weaker version with a carbon fibre scoop actually won AWS 31
        Really reminds me of the antweight Shazbot from Team Nightmare. Great job!
          I was planning a robot like that, but I might not build one like it now
            Changed the arm-servo from the cheapo chinese one to a modified Hitec HS-7954SH. The previous one had stripped a few teeth so I'm hoping this one will be more up to the rather violent motion the arm goes through when 'somersaulting'.
              What kind of motors do you use for that weightclass? And where did you get those tracks?
                Tracks - http://osbots.com/shop/product/tank-tread-set/ (got a set of soft-rubber wheels too which are actually grippier but the tracks can climb over things.. and look cooler)
                Motors - http://banebots.com/pc/MS-16XXX-050/MS-16038-050
                • #23
                  You can of course use other motors though!
                  • #24
                    Thanks, was looking at some motors between the antweight class and drill motors as i wanna build something in between aswell as another project
                    • #25
                      Swapped out the 11.1v battery for a couple of 7.4's in series, it's very cramped in there but now goes a lot faster!
                      Still no beetleweight competitions...
                      • #26
                        if you had enough power in the lifter motors, add some spikes onto the scoop on the correct side then it could double upm as an axe
                        probably a crap idea but would look dam good
                        • #27
                          Any videos with the higher voltage and new arm servo running? I just love how the thing looks!
