Team Thrifty /Fifty Build Diary for Bitza
  • #76
    Re: Team Thrifty /Fifty Build Diary for Bitza
    I may try and hack a servo to create an RC relay.
    What is it exactly that turns low power gate of the big relay on and off? Does it just listen for a current?
    • #77
      This is in keeping with the Bitza theme..
      http://trebor69.tripod.com/speedcnt.html
      you should be able to use the fets and heatsinks from any stripped down drills.
      same thing with power transistors.
      http://www.rc-airplane-advisor.com/elec ... oller.html
      http://www.rc-airplane-advisor.com/elec ... hotos.html
      DON'T TRY AND RUN THE CONTROLLER AS A SPEED CONTROL ..IT'LL GET TOASTY!...on and off should be fine...maybe.....
      • #78
        Good find!
        Should I just use these to control a bigger relay then?
        • #79
          no you could use the mosfet to directly control a motor
          • #80
            should have said, you will be able to pick up the resistors and FETs off ebay for next to nothing
            • #81
              Cool. We have a huge stack of dead drills in the workshop at the moment so I'll raid them for MOSFET's and resistors, see what I can find.
              Cheers for the advise, this is very Bitza!
              • #82
                Up to you... depends on the rating of the fets or power transistors.
                You could just hook up the servo wires to one of these instead of the fets or power transistors.
                http://www.jaycarelectronics.co.uk/prod ... ?ID=SY4086
                ..you'll need to find / buy the resistors as the drills don't have them.
                • #83
                  That was my original plan when I mentioned hacking a servo, just hooking it up to an existing relay.
                  If I can't find MOSFET's powerful enough then I'll do that
                  I've got loads of different rated resistors laying around, I'm sure I can make up what I need.
                  • #84
                    Good find!
                    You should browse the web more .... I found those pages years ago.
                    Here's another 2 dug from the depth of my favourites that might interest you.
                    http://www.rctankcombat.com/articles/speed-control/
                    This second one is a copy of the page that once resided here .. http://www.x-eng.co.uk
                    http://www.teamonslaught.fsnet.co.uk/Rotraktor.htm
                    • #85
                      That page is great. It puts into words and diagrams most of my disjointed musings.
                      Don't worry I do browse the web. I just know there are some neat and very robo combat specific solutions that I would only learn from here.
                      Most of the time it's what I was already thinking only in a more viable/logical form!
                      • #86
                        Thinking about getting a Spektrum DX5E for new Bitza. Any reservations?
                        Also does it come with the type of mixing we all use to drive robots. I don't know what it's called, but it's advertised as having Delta Wing mixing, what ever that is.........
                        Thanks,
                        • #87
                          Delta wing is an Ele and Ail mix.
                          BUT ...I think the DX5 has a reduced output when using the transmitters Delta wing mix....
                          IE.. Your bot might only go at 1/2 speed.
                          • #88
                            Go for the dx6i and I'll send you the YouTube link on how to get full throws but remind me as it's at home on the computer
                            • #89
                              I don't think that the mixing has redused throw, ie half speed.
                              I use it for my planes and I think it has the same amount of movement as normal.
                              You could always buy a dx5e and get a mixer as well if this is the problem or....
                              Buy a ESC with a built in mixer eg Sabertooth, SyRen, Scorpian.
                              You could go for the DX6i which is very nice but the dx5e is still very good.
                              I use a planet T5 with a sabertooth, which has built in mixing. This is almost the same as the spektrum but the planet, unlike the spektrum, doesn't have a failsafe.
                              • #90
                                Thanks for the offer of help but we are getting a DX5E because we can get one cheap.......
                                Don't really want to start buying additional mixers and none of our ESC's have built in mixing....
