Robo Challenge - Predator
  • Re: The latest machine from Robo Challenge
    Turning the inside edge so it matches the inside of the head
      Finished turning and now im drilling the bolt holes
        Hey presto! gear finished. Fits nicely into the head
          I was just thinking the other day there are no bots in the UK with direct drive on a spinning weapon. (Except LS4 maybe...)
          Are you not worried about stripping gears?
            As long as you get the PCD of the gears correct then there shouldnt be a problem. Ive gone for MOD 1 gears here which I think will be fine. Ive also used a gears with more teeth on to create the same gear ratio so I have a bit more 'meat' on the drive gear. Only testing will show if it works so fingers crossed. as the head cradle is rubber mounted that will absorb a bit of the shock. Also the disc is tilted so the machine will probably fly when it hits.
              Will be fine... 360 used direct gear drive and never broke a tooth.
                Looks amazing James nice work I rember seeing this at your work when it was part done and thought can't wait to see it working that was years ago :P Fantastic looking thing
                  Thank you very much Alex !
                  Just made some custom bolts for the arm pivots. Looking good so far. Next step really is to make the head plate and the tooth ring. Then I can get cracking on finishing the drive system and the arms mechanism.
                    how are you planning to power the side arms?
                      There will be a pivoting screw thread which both arms attach to. This is powered by a worm gear to get a high ratio with an astro to power it. It's quite a complex movement the arms make. They are designed to be parallel when the arms meet at the top. Obviously the arms are tapered and if you had a simple hinge on them they wouldn't sit flat on the ground when they are down. So as the arms come up they pivot inwards aswell to create the nice lines. It's just down to the linkages really. Iam just finishing off the design for the arm mechanism and it's really nice and tidy. Will be pleased to see it completed.
                        Very nice James.
                          Than,s very much Shane, was hoping to have it ready for the champs but that doesn't look likely lol
                            Pretty cool how you made it onto the banner without even finnishing the robot! lol;
                              Haha, Dan took that photo at last year's Champs so I sent it to Kane. Thought it would make a good banner.
                                lol How good is that !
                                Doing a bit more work on it today. Designing the single tooth rim for the head and Im working on the arm mechanism. Its coming together
