Tron
    Re: Tron
    Dan was playing around with a similar idea and seemed quite keen until I pointed out that it would be ineffective against Ali, Ti (wood) or any of the plastics (Polycarb, Nylon, HDPE) which are pretty popular in robots.
    I'm assuming it would work against Hardox and obviously any steel used and I don't see Nickel or Cobalt catching on as robot armour.....
      Re: Tron
      got a data sheet or any more information on that magnet Craig?
        Re: Tron
        Looks Cool Craig,
        If it ends up not being very good you can always call it tron legacy
          Re: Tron
          Dave the link is below
          http://www.tme.eu/en/details/em-hs5030- ... 030-12vdc/
          some answers
          The north and south poles are on the same side (the front) so the magnetic field is very small the armour of the opponent robot would serve as the keeper,
          I doubt if much if any of the magnetic flux would penetrate too far into the robot, so it will not cause any problem.
          I know about the wooden or plastic robots but even these have some parts that could be steel on the outside and I'm feeling lucky!
          If we don't try new things we could end up with a field of wedge flippers
            Re: Tron
            Thanks craig!
            Jonny- i doubt it would cause much of an issue... in 360 ive got the rx double sided taped down on top of its magnet running right next to a big brushless motor... and ive never had interfearance issues
              Re: Tron
              Ellis not jonny^ :P
                Re: Tron
                Ah, the one benefit of having a wooden robot :P
