Angel
  • Angel
    Starting a little project this time it is a Middleweight robot similar to Seraphim but this time I want to make it an all terrain project as well. There aren€™t at the moment many middleweight robots about!
    So the Idea is to work on some wheel designs for all terrain type running. This way I hope to see if I can make a design that will go up steps or across rough terrain and steep inclines.
    I have seen some designs on UTube and they are ok, but I think I could do it differently the Team Saint way.
    The rear bulkhead and motors fitted.
    Re: Angel
    looks good
    does this mean no weapon?
    i can see the saint style weapon getting in the way when going off road
    alex
      Re: Angel
      For the fights I will probably use a small sledge hammer.
      For off road I will probably make some sort of skid or Wheel as I don't want to dammage anything.
        Re: Angel
        What with the new heavy weight robot I have not done much to the Angel, it now has the battery tray. radio, speed controller and link housing made.
        The speed controller is going to fit under the battery position and this will be also the link and radio position.
        The batteries will fit on top in the tray, with some roam rubber to help with all the shock.
