RogueTwo Robots
  • Great bunch of advice there Dave, thanks. I did double up the wheels when I was sussing out what to order for myself, but just forgot yesterday as it was a rushed example. I've used the green and blue Banebots wheels and experienced the fluffing effect. The blue ones definitely last longer but you still have to change them fairly frequently compared to, say, traditional Blue wheels.
    Think I'll probably just stick with the 124mm wheels; I did look at the CADs to see how workable it would be to downsize but I'm happy with the current setup. I'll be placing my Banebots order in mid-February (when I get paid) so if you haven't got your 50A shore wheels by then, feel free to stick them in my order to save on shipping.
    • Update
      Took a trip home this weekend and found this nice pile of roboteer's presents waiting for me. Who says Christmas only comes once a year?
      Several tonnes of packaging later, it was broken down into this:
      Sorted out tools-wise for the milling machine now. The yellow box is a set of collets and holder for the endmills as I only realised a moment before placing the order that I couldn't just stick the cutters in the chuck.
      The drills are for the drum shaft holes, spade bits ain't going to cut it anymore. The 20mm one is for when I get a new drum made and upsize the shaft but the current drum has 17mm bearings fitted so can't do much there. Also threw some needle roller thrust bearings in there too. Hadn't planned to use them but they were on discount at the same place that I got the collets from so I figured why not.
      The aluminium from AW needs cut and milled down to size so hopefully can make a start on that tomorrow and have something a bit more tangible to post
      • Is the ally structure your robot body? If so where did you get it made and stuff?
        • It's just the cut to size option from alu whorehouse isn't it?
          Hows the finish on the cuts Jamie? I'm going to be almost copying that photo part for part in a weeks time lol
          • Is the new Drumroll going to be ready for the champs Jamie?
            • Are you a wizard?
              What grade you go for mate? Btw ed prob still has the CNC code for 720's bulkheads of you wana save some time... Lol!
              • I haven't started making my bot yet either, 2 months is loads of time right?
                  Yep, it's the main chassis. It will have outer Hardox armour as per the current version. The aluminium was just cut to size by Aluminium Warehouse and posted out.
                  The finish on the cuts was fine, flat but just with sawblade marks. Tried to get a good photo of it but it doesn't show up that well. And a comparison shot with the finish from the mill cutter.
                  It is worth noting though that the pieces were oversized; both the length and width were about 4-5mm more than what I ordered, but it does say on the website about tolerances and since I was needing to cut them down anyway, it was no problem. Just as long as you don't expect the sizes to be as exact as something that's been CNC'd, it's fine.
                  Hopefully! The current Nylon chassis can't really be used anymore so it needs the ali chassis, but I've only got limited time to work on it so I'll be keeping my fingers crossed.
                  The roboteer's old faithful, 6082 T6.
                  Are you a wizard?
                  Lolwut? :P
                  • ​Update
                    Another weekend trip home, another pile of goodies waiting;
                    Two of the ESCs will be used in Onyx but shall double up as spares for Drumroll if needed (probably not likely). Was going to go for blue Banebots wheels as well but neither they nor Technobots had them, so defaulted to orange - it's now going to be even more of a 720 ripoff :P
                    Thanks to Grant as well for setting up the Optipower discount, two packs of that quality for the price I paid is a bargain.
                    Had hoped to have the Banebots order waiting for me at the weekend as well but there were customs charges to pay so it didn't get released until today. Got stung to the value of £50, wasn't expecting that much! Will need to factor that in the next time I order from there.
                    Had also hoped to have the chassis up to a more photogenic level by now but didn't manage anywhere near as much workshop time as I'd hoped due to projects for work and some DIY that needed done. Only just finished up milling the chassis pieces down to the right dimensions, so a bit behind where I'd like to be, but hopefully a full workshop session next weekend will take care of a lot of that. In theory once the chassis's built and the drives fitted, it's just a case of putting all the gubbins back in (though when has it ever been that straightforward) so still confident of getting it ready for the champs.
                    • Goodies! Yay! Nice goodies too, by the looks. What size/ratings are those packs? I got the discount too, was very pleased.
                      • The packs are 5S 3650mAh 35C ones. I thought about going for the slightly higher capacity 4300mAh packs since they were only a few quid more expensive but with the bigger 775 motors this year, internal space is tight and the smaller size of the 3650mAh packs are better suited to the robot. Capacity shouldn't be a problem as the old packs were only 2200mAh and I got about 4 minutes out of them.
                        Found out that the Banebots order arrived today so it'll be all systems go next weekend
                        • Brilliant. I'm really looking forward to seeing this Drumroll.
                          • Likewise Harry, looking forward to seeing the new Massacre, and love the blog
                            Hopefully this Drumroll won't break down within ten seconds of its first qualifier this time!
                            • I did notice the new fuses :P
                              • Drumroll is going to be a definite contender this year, on a different note Jamie if you don't mind me asking what is the weight of the axe on Onyx? i'm trying to work out what reduction to run as i've got a 1.5kg axe on mine running off a similar set up.
