Team Terminal Damage
Well the Rebel Robots draw is up as you probably all have seen. Kaizer Mk.3 gets a baptism of fire by being drawn in the same heat as Kishar, Pillow Torque and Hornet 2. Ive never fought against Kishar or Pillow Torque but one has an immensely powerful spinning disc and one has Astroflight C40s for drive. And then of course, theres just the small matter of Hornet 2. Easiest heat Ill ever have!
Maybe I shouldnt be writing off my hopes just yet however. The chassis of Kaizer Mk.3 will be made up of interlocking bulkheads of HDPE, 12mm thick. That should hopefully stand up to a good few hits from Kishars blade. Same goes for Hornet 2, although I expect to be tossed around a lot in that fight so Ill need to make sure my internal connections are all up to the impact stresses. Kaizer will be out-maneouvred, out-run, and out-pushed by Pillow Torque (to be expected when you put cordless drill motors against Astroflight C40s) but you never know, a quick slide under of the lifting forks, a charge against the wall and you could have yourself one stacked robot
Drumroll got drawn against Pain In The Asp, Tuff Luck 2 and Hooligan. Pain In The Asp is the one I reckon could cause me most damage. Tuff Luck 2 will be resiliant to attacks with its hardox shell and Hooligan is a bit of an unknown quantity although I have seen footage of it in action. Its got three flat sides and the front wedge so could be a bit challenging to gain purchase but the design of the new teeth for Drumroll will hopefully be able to grab it somewhere.
Jamie
Jamie
) so youll just have to wait until Rebel Robots to see the new look
