Tanto 5
  • Tanto 5
    Tanto 5, the 5th and final 2 Wheel drive version, got a 4WD version designed
    Tanto back with its Eteks, twin Roboteq 2550 SCHE, 36v Pack
    structure is made of steel its bolted and welded final version of this will be 30mm front forks and 12mm top and bottom plates
    Gonna top around 25mph
    its 250mm tall
    550mm long
    580mm wide
    wheels are vulc same as Storm II
    All signed up for the UK champs more pics to follow....
    Re: Tanto 5
    empty chassis
    Being built on the mill
    current weight is 70.8KG
      Re: Tanto 5
      Love it, is it even smaller than before? The forks are a lot better. Can't wait to fight it.
        Re: Tanto 5
        indeed, and I know I can make it smaller too
        design wise its got all the bits that worked in Tanto 3 (which was the best one) and the bits that worked from Tanto 4 (which was pretty much only the gearboxes) and made it as small as i could, whole thing was cut out of 10mm and then machined to shape
        dispite being rusty its the best Tanto we've made I think
          Re: Tanto 5
          looks light, might try get it over the the cage bits in the rr arena
            Re: Tanto 5
            at presents its 70.8 without the top armour or addition plates will be about 95kg when its done
              Re: Tanto 5
              oo take that back then, you going barnsley?
                Re: Tanto 5
                indeed, doing as many events as my body will let me this year
                  Re: Tanto 5
                  John, my heavy will be at Barnsley hopefully and will be quite light, so feel free to have a go with it. lol.
                    Re: Tanto 5
                    ha, have you got a photo of your bot?
                    its the iron awes you will have to watch out for :P
                      Re: Tanto 5
                      dispite being rusty
                      Go on, get it sandblasted or something
                      Looking very nice Craig, good luck with the rest of it. Hopefully I will be making it along to Barnsley (just waiting on some info before I can start confirming things) so will love to see it in action.
                        Re: Tanto 5
                        wheres the weapon
                          Re: Tanto 5
                          95Kg travelling at 25mph is weapon enough for me!
                            Re: Tanto 5
                            there may well be something to sit between the top forks.......
                              Re: Tanto 5
                              How about Anton du Beke?
