Miniroll
This topic is closed.
  • Miniroll
    Hi everyone!
    Im building a 6kg version of drumroll, because i love the design so much!
    I cant make it exactly like original drumroll, because the lack of some materials, but i´ll try my best. Drum material was hardest to get so i got only a 50mm material it looks a bit small for the size. Drum has plastic endcaps and has 4bearings and 12mm shaft.
    Re: Drumroll mini
    Looks like it's coming along nicely
    I'd like to get an antweight Drumroll built and I've got motors that I could use for the drive and weapon of a middleweight Drumroll so all I need is a heavyweight one
    Will be nice to see your version running; roll on the 2011 European Championships
      Re: Drumroll mini
      whats happening then ?
        Re: Drumroll mini
        Update!
        Wedge needs some work, and im going to make a new top cover too.
          Re: Drumroll mini
          I seem to remember someone saying that European Championships would be held every four years, so I'm just assuming that there'll be another one in 2011. Could be wrong though; but the Eurochamps are the only place I've seen 6kg machines competing so it's where I would expect to perhaps see this mini Drumroll in action
            Re: Drumroll mini
            right ok mini Beauty then ok
              Re: Drumroll mini
              That will be Beauty 3 after the 2009 uk Champs then John?
                Re: Drumroll mini
                B3 is to far gone but just may be just need to make a small ram hehehe
                6k u say whats the smallest co2 bottle around i need to find
                  Re: Drumroll mini
                  The smallest is 3.5 ounces.
                    Re: Drumroll mini
                    ok leo where do i get one of them then ?
                      Re: Drumroll mini
                      3.5 oz CO2 bottles are paintball equipment so I'd try a paintballing shop (if such things exist)
                        Re: Drumroll mini
                        They do exist and the cheapest place to find 3,5 oz bottles is on Ebay.
                          Re: Drumroll mini
                          I should have said places because I meant it about the shop.
                            Re: Drumroll mini
                            How do u fill co bottles? Is it possible with dry ice?!
                              Re: Drumroll mini
                              No, you fill CO2 bottles with liquid CO2. It is basically decanting from one bottle into another. If you are not familiar with the process I suggest you attend live events where experienced roboteers can show you first. Do not try to do this on your own the first time it can be very dangerous.
