The Internals of the valve have changed alot so hopefully the robot works alot better now.
I dont have any pictures of the robot from when it was built up and driving before the minor accident it had. But here is how the bulkheads and system sat before its self destruction.
How powerful is Flow!? Can't believe it ripped apart it's bulkheads like that. Looking forward to seeing it in action.
In this image:
How do you plan on transferring drive from the pulley to anything else? I've got a similar problem where my bearing takes up all the 'meat' off the boss, so there are little mounting options.
Fixed baseplate to the bulkheads and fitted the drive system and battery box
Ill upload a few pictures when I have done a little more. Got to take the system out and drill the buffer tank for another pneumatic fitting. The system is going to be pretty trick when its done. When you see all the plumbing in this robot you will be thinking WTF?
