THE LONG WALK!!
This topic is closed.
  • #31
    Re: THE LONG WALK!!
    This video is probably the closest thing to what i hope to make but my one will be much bigger.
    http://www.youtube.com/watch?v=HrVAE...eature=related
    • #32
      Re: THE LONG WALK!!
      thats electro luminiscent wire (EL wire ) it requirs about 2.5 KV input to work , but inverters are available , i think maplins sell it if you are after some , most people use it in custom pc cases
      • #33
        Re: THE LONG WALK!!
        That is awesome, if you can make it anything like that Craig, it will be a big hit and I€™m sure you will!
        Stu- you want that music for RR!
        Tom
        • #34
          Re: THE LONG WALK!!
          Hi all
          this is a picture of the drive pods the motors are in and the transmision is going ok. the walking pace will be about 42 per minute, I have had the leg bushes machined up they are made from Oilon oil impregnated nylon.
          http://s569.photobucket.com/albums/ss13 ... GA5024.jpg
          • #35
            Re: THE LONG WALK!!
            OOps it is a bit big!!!
            Next to the dustbin you get an idea on how big the walker is going to be, it is about 1.5mtrs long and just under 1mtr high at the moment but finnished it will stand just over 1 mtr tall.
            http://s569.photobucket.com/albums/ss13 ... GA5030.jpg
            I hope i can get it in the van
            • #36
              Re: THE LONG WALK!!
              That thing is huge !
              Hope the rest goes just as well.
              • #37
                Re: THE LONG WALK!!
                Some pictures so far on the walker
                I now have 4 legs sub assemblies so when the support brackets are finished I will be able to dummy up the first pod to see if it actually walks!!
                Also I have dug out some 12 amp/hr batteries for the power, I will probably have one battery in each pod with connecting wires between them.
                http://s569.photobucket.com/albums/ss13 ... GA5034.jpg
                • #38
                  Re: THE LONG WALK!!
                  Anyone want a go at making this type of walker?
                  http://www.youtube.com/watch?v=RI8VD...c-HM-fresh+div
                  • #39
                    Re: THE LONG WALK!!
                    [quote=craig_colliass]Anyone want a go at making this type of walker?
                    • #40
                      Re: THE LONG WALK!!
                      Jordan
                      It might be a bit hard if you want to make that walking robot out of Lego try this type.
                      http://www.youtube.com/watch?v=MqIehwrnF5E
                      • #41
                        Re: THE LONG WALK!!
                        Just to keep you up to date
                        Pictures of the 6 legs finished only 2 to finish and some of the bracket assembly to connect the legs to the pod. These I have made adjustable so I can vary the distance from the crank to the leg pivot I think this dimension will be quite critical and I don't know exactly what it should be!!
                        http://s569.photobucket.com/albums/ss13 ... GA5036.jpg
                        I have found this project so far to be very interesting to do I hope the result will be entertaining for whoever watches it go.
                        • #42
                          Re: THE LONG WALK!!
                          It's all happening at the moment!!!
                          http://www.youtube.com/watch?v=skhb0IkkzyQ
                          • #43
                            Re: THE LONG WALK!!
                            That's some hypnotic leg movement
                            Well done Craig, the build seems to be coming along really well! Best of luck for the rest of it
                            • #44
                              Re: THE LONG WALK!!
                              i could stare at those moving legs for ages lol
                              how much longer do you think the walker will take you to make?
                              • #45
                                Re: THE LONG WALK!!
                                Hi to answer your question on how long it will take. I hope to get the first pod to a stage that all 4 legs will operate with a cobbled up battery by next week.
                                If I can keep working on it through most of August I hope to get the second pod going. :shock:
                                I have a feeling the robot will never be €œfinished€, as I will probably keep adding bits for years to come but I want it to be sort of ready for the winter tour.
                                I think with all 4 sets of legs going it will be quite hypnotic :shock: :shock:
