Things had been going well, but im starting to run into a few problems. Most of all the current predicted weight is 15Kgs, still got all my weight saving to go in yet but that still leaves me at 13.8Kgs. Also the regulator doesn't fit so i will have to modify it. Most of the armout in now done or at least cut out although not mounted properly.
Whatever you do, don't actually weigh it until you're sure it's underweight. Because Dave W said he'd eat Satanix's steel lid if it comes in under weight the first time you weigh it and, well, that's something I really want to see
Ed- you can get it in weight easy, take loads out of your gearbox's, abit out of the astros like mine, spur gear on the axe, gun drill the piston rod, smaller lipo then what you planned etc etc
