Hey all,
i'm currently in the midst of putting SB back together, and in the process i have created a new wiring loom, with everything modular through JST's.
for the drive i'm still running the "standard" planatary gearmotors wired to a tinyESC each, and into a flysky FS-R6B reciever. This is the setup i ran at bugglebots, and in further iterations.
Everything was working, i stripped it all out, re wired, the ESC's are getting power, but now my reciever flashes red once and then does nothing.
i have also tested on an FS-iA6, and i get no lights at all (this reciever hasnt been tested, so could well be broken).
Checked polarity, checked with a turnigy plush 40A also and no joy. Interestingly when i removed the plush esc the reciever did flash in its bind mode for around 10 seconds before going back to nothing.
i have re-fixed the esc connectors as they were loose and i though could affect operation, but still no luck?
Any thoughts or just new reciever time?
Sorry for the long post, TIA!
Bam
Bam
