Beetleweight wiring question
  • Beetleweight wiring question
    Just trying to wire up my beetle weight and am confused.
    (Here's a messy pic, of my components: two motors, 2 vex 29s, a BEC, servo, LED, lipo, receiver and removable link)
    Does the battery just go into the receiver via the BEC or does it have to connect to the speed control or servo?? Also where does the removable link / LED have to go??
    Thanks to anyone that can help
    To try and answer your questions directly...
    I don't think you need the BEC in this instance but you will need to check the VEXs to see if they have a BEC in them (I think they do). You'd wire the battery to the ESCs (speed controller) and then connect the JR signal wires from the ESCs to the receiver. The servo is powered from the receiver. However, take the above with a pinch of salt, I've not used separate BECs before.
    I tend to put the removable link (and the fuse, which is mandatory if you are using a LiPo but good practice regardless of chemistry) on the positive wire in between the battery and the speed controllers. The LED would be just after the removable link. I have a very rough diagram available from a PDF I am putting together on such things.
      And here is the diagram. I need to add in the receiver wiring as well.
        Hey man thanks for the advice. Just remembered that according to this page (https://bristolbotbuilders.com/parts.html) the vex's need to be used with a 5V 3A BEC to the reciever. Never sure if this means the vexs dont have built in BECs though
