Beetleweight rules ?
  • Beetleweight rules ?
    I'm struggling to find official beetleweight rules if there are any.
    Mainly regarding the maximum size etc of the robot eg length width or does it just come down to weight ?
    Don't want to keep on building to find I have broken a rule lol
    Also is there a battery voltage limit
    Sorry for the maybe obvious questions but after a quick search I haven't come across much information
    Many thanks for reading
    The Beetle rules are the same as the rules for all other weight classes under "Health and Safety".
    If there is no mention of a rule, then it doesnt apply unless the EO makes it an additional. For example if there is no mention of a size limit, it is because there is none. So long as the robot fits through the arena door it can enter a fight.
    The only real rule difference beetles have compared to other weight classes is allowing 2 robots per driver.
      Wouldn't that also be at the discretion of the EO?
      The rules, as pointed out, apply to all weight classes unless the rule specifically state that they only apply to a specific class (so off the top of my head, inverted links only apply to Heavyweights for example and the types of allowed transmitter).
        Yes thats also at the discretion of the EO, however in general as standard its 2 robots per driver.
        For example, I have allowed 3 robots for one driver before on the basis they was entering a fun non competitive robot. Similarly at UWE we got so many entries we had to prioritise the first robot for every driver so now most drivers 2nd robots form up the reserves.
          Fair enough, I was casting my mind back to the FRA Featherweight championships this year where it wad 1 robot per driver rather than 2 robots per driver.
            Yes featherweights are generally always 1 robot per driver as per the rules as written, its Beetleweights which tend to be the exception
              Hi Michael, I cannot find any max dimensions for a Beetleweight robot, are there any or is just covered by weight (1.5kg)?
                That is correct, there aren't any max dimensions per se for Beetles or heavier apart from those specified in the FRA rulebook. For reference, my beetleweight (Shu!) is 16.4cm x 32.5cm x 26cm (length x width x height).
