Beetleweight Brawl 2018 (unofficial thread)
  • Beetleweight Brawl 2018 (unofficial thread)
    Hi All!
    Got my confirmation that i shall be participating in the Brawl in Bristol (not quite the thriller in manila but hey!) which is super exciting and i cant wait! My entry Batteries Not Included is almost done really, just need to tweak a few things. One of those tweaks is an LED for the on switch. I know i need to put in a fuse before the LED but im unsure what to get, any help?
    On a side note, the shell of my robot is covered in stickers so if any teams/company's out there want to donate to the cause and get some free advertising either PM me and ill give you an address to send to or bring them on the day!
    Looking forward to getting stuck in!
    Theres 3 main ways of doing it.
    Put a fuse in the line, put a blade fuse and holder in the line, or use fuse wire on the link connector.
    Oh btw - "LED for the on switch" - remember it needs to be a removable link due to safety
    Edit: Oh btw, any pictures?
      I was thinking about how to add a light easily. I came across this if your power is 12V or under it would work out the box. I have seen light strips on EBay too that claim to have built in resistors.
        TBH, the robotshop LED would be enough though do make sure it is contrast to the background panel if it isn't bright enough. For ease of maintenance, I put in a blade fuse with holder into my Featherweight and that does the job fine. It'll be the sort of thing I'll use in Shu! when I am there... need to get it built first. :P
          [ATTACH=CONFIG]7424[/ATTACH]
          Just to confirm my limited Electronics knowledge ( it was a while ago ok ) if you ran two of those LED strips in parallel it would require 24v to power it or am I mistaken.
            You have parallel and series the wrong way.
            2 in series wants 24v (where the negative of one is wired to the positive of the next). 2 in parallel will want 12v.
              Great might get two of those LED strips + some more wheels for my feather
                Actually, it does have a fuse as a removable link which is a good point! And that happens to be a blade fuse. I like the idea of the LD Strip though, would be pretty cool!
                Will probs tidy it up a bit as all things arent in there final positions but ill post a pic or two sometime.
                Thank you for the responses!
                I got drawn up against Kamikaze in group D, found a vid of it at last years Brawl and it looks fearsome!
                  Hey all, having some problems with my brushless motors and need some help. I've bought some turnigy brushless motors and ive hooked them up to a brushless esc (obviously) but the motor just makes a beeping sound at me. Any ideas?
                    What sort of motors and ESCs are we talking about here?
                      turnigy 22260 3000kv 650v and hobbyking 60a sbec
                        Sure it is the motor beeping? More likely to be the ESC (not clued up on this Brushless tech yet so could very well be wrong :P). The ESC manual suggests that there is no throttle signal being received (1 beep followed by a pause).
                          you sir, are a genius. didn't know there was a manual, just found it. Lemme have a look as its not that type of beeping, its a really quick one
                          its something to do with the throttle not being in the lowest position, will try to find the correct channel and mix. Problem solving people!
                            From the manual, looks to be that you need to reset the throttle position and set the pull rod to the lowest position.
                              Is 60a the recommendation for those motor's? I've found Afro ESC's are pretty bomb proof but they only go up to 30a but with the rounds only being 2 minute's, heat might not be to much of an issue.
