So a lot of people search to be using HDPE. Personally I've used UHMWPE. Is one better than the other? I am struggling to work with mine (6mm sheet) any recommendations on how to accurately cut these plastics and which tools to use?
HDPE vs UHMWPE
We use 5mm hdpe for fat lip with 8mm on the front. Nothing so far has caused any damage of any note and it fights spinners regularly.
To cut use a metal ruler. A Stanley knife and do a few passes. Go at least half way through and then use a pair of pliers to break. Obviously that doesn't do curves but you can use a saw for those bits.
UHMWPE is much harder to work from what I hear. I'm told it's rather slippery so can't be easily secured using things like clamps, so some people drill holes and pin it that way. I can't confirm this but Robert Cowan, a builder in the US, has stated it provides some benefits with this slippery nature as other weapons and wedges struggle to get a grip. But again, I've not used it so I can't say for sure!
