Hi,
I´m currently planning my first bw and got some questions about the 25mm motors.
I´ve already found out there are good but also some bad ones. Is the difference the gearbox or the motor? (I´d guess motor).
Since testing with my raptorweight featuring blheli-flashed escs has been quite successfull so far, I´m considering going straight to brushless. If the motor would be the faulty part I´d use cheap ebay motors and wouldn´t "waste" Elli´s good ones. For choosing a bl-motor it would be helpfull to know what ratio the gearbox (f. ex. of the 1000rpm motors) has and what diameter the shaft of the motor itself has (I´d like to reuse the pinion).
Or if somebody got a proven bl-setup providing similar performance as good 1000rpm motors I´d be keen to hear about it.
Thanks,
Ralf
Thanks,
Ralf
