Cheap Drive ESC
  • Cheap Drive ESC
    So I was doing some research whilst designing a beetle weight ESC when I came across these:
    http://www.dx.com/p/jb-diy-10a-brush...3#.U6csjfldWSo
    They're very cheap at about £5.50 each, and have free shipping to the UK. They only do 2 cell lipos, but at 10A with 20A peak they should do fine for beetle weight drive. The reviews look good as well. Has anyone else come across them previously? Seeing as I'll never beat them on price, I'm just gonna buy a pair of these instead of making my own for once :P
    I'd be worried about a forward/reverse delay. Nice price though. The voltage is a massive limit, but I would wonder if they would handle 3s fine anyway, or maybe with a heatsink or something. Still got to be botbitz for me. £17 gets you a pair, but then you get a little stung on postage and the couple week wait. Very neat find though
      I've seen those before on Ebay in 10 and 20a versions, the 20a ones state that they can handle 3s but then also have a voltage limit of 8.4v stated so who knows. They're a good price but you'll probably wait just as long for them as you would a set of Botbitz and for around £25 a set of Botbitz are cheap and you know they'll last.
      Edit: Almost forgot here's the link for the 20a version in case you wanted to have a look http://www.ebay.co.uk/itm/RC-ESC-20A...item3f363a2e2a
        All that being said, when Chinese or off brand stuff is good, its good. I have £10 escs working better than electronize ever did. Might get a pair of Rory's linked ones to see what they are like and if they can handle my abuses.
          ive tried the 10a esc already there naff, the ones with a brake just stop if you try to go from full forward to revers until you center the stick and put it in reverse again and if you get the version without a brake and use a mixer it tends to twitch when your not touching the controls and 1 side will drive a bit faster than the other
          also if you over volt them to a 3s lipo they get warm very quickly
            I plan to get a pair some point soon, partly just to reverse engineer them to work out if they have any weak spots/ what their real specs are. If need be I may be able to just upgrade some components to improve the spec. Bear in mind that the featherweight ESC I made cost me ~£20 and locks up if you accelerate too fast, this is likely to be better than my thrown together homemade one would be on price, delivery time and quality.
            The power wires on that 20A ones look a little on the thin side, those probably could do with upgrading a bit. The MOSFETS on it do at least look like they're up to the job. Might even be possible to up the current rating with a bit of hacking if required. Might have to get a pair of the 20A ones to replace the ESC in Richie if I can't fix the lock up issues; The difference between £13 and £25 for an ESC is substantial when the total budget for your robot is £100 :P
            Edit:
            Hmm, that sounds like current lockout.. what motors were you using with them?
              i tried them on the usual BW motors
                is it possible to remove a current lockout as i have some other esc with the same issue
                  The overcurrent lockout is a built in safety feature of a lot of motor driver chips; if the current spikes above the maximum, the chip will shut off all outputs until the chip is returned to brake mode (center stick). It's a really unhelpful feature when used in fighting robots; I had similar problems when designing my ant weight and feather weight ESCs. There's no way to remove it as far as i know unfortunately, other than to slowly ramp the stick from forward to reverse like I have to when driving my featherweight. There must be some solution though; my featherweight uses the same driver chips as the Scorpion XL ESC, which runs drill motors fine as far as I know...
                  The 20A one just uses 4 MOSFETs, which means it'll have none of the fancy safety features built in. They may have added extra circuitry to include it, but that should be easy enough to remove if necessary. I might get these for a beetle then, if the 10A ones are a little suspect...
                    lol i have 1 of the 20a 1s all bagged just gave it a quick test and they seem to work ok
                      but i would make sure it says the don't have a brake as i think you can get them with or without
                        These are the cheap 20A ones without brakes on the website i found: http://www.dx.com/p/jxh-xys-bl20a-20...8#.U6dNDvldWSo
                        Though I find a robot without ESC braking can be tricky to control, as it carries on moving when you release the sticks.
                        EDIT: Also, motor braking shouldn't affect that ESC, as it's way over rated for the a BW motor so should be able to handle any amount of stick waving, brakes or no.
                          well they seem to stop when you take your finger off the throttle but don't stop when you go from forward to reverse .... and they have the same sticker on as mine
                            All the brakes do is connect both motor outputs to 0v when at center stick. The motor'll stop at center stick with or without braking, but will be much harder to turn with braking. So when moving from forward to reverse quickly, the brakes will have little to no effect on the motor.
                              Didn't know Hobbyking did brushed ESCs... 30A continuous, 3 cell, under £5, UK stock, and good reviews... buying now!
                              http://www.hobbyking.co.uk/hobbyking...arehouse_.html
                              EDIT: Not buying now: no reverse
