fuse question
  • fuse question
    Hi all
    In the fra rules it says I need a fuse for a lipo that is below the maximum discharge of the battery.
    So, if my battery's nominal discharge is 60amps and the burst discharge is 100 amps, what size fuse should i use
    I'd suggest a 70a or 80a. Basically, the lowest you can get away with that doesn't blow under regular conditions.
      Cheers ellis, 80 amp it is then
