I think Harry tried the 3s rated 10a botbitz on 4s to see how they do, and as expected they got quite hot. The testing here was done on a 5a sabertooth which seems happy (but did get warm) running the 4 1000rpm gearmotors on 4s. He'll probably confirm details in the next 24 hours.
A thing about motors
I'm gonna begin work soon but its modifying the open source code available from botbitz for the f-20a and f-30a for the spectrum kit. For specs, just look on hobbyking but when I've had a go, I'll publish the results online.Originally posted by razerdave View PostTake it from me, you will need to upgrade
Dan Laybourn is working on a code for the Botbitz 20A, because it's the same make as the TZ85's. This means no random failsafing, and with a 3A BEC and the capability of 4S +, it's going to be a good move for beetles
I would be eternally grateful if you could find a fix for this. They seem like really good controllers if you don't need to mix, which is the issue with the current code...Originally posted by Danjr1 View PostI'm gonna begin work soon but its modifying the open source code available from botbitz for the f-20a and f-30a for the spectrum kit. For specs, just look on hobbyking but when I've had a go, I'll publish the results online.
