I've decided on the weapon motor after a very long and tedious search http://www.hobbyking.com/hobbyking/s...dproduct=14736 new stock is currently "in transit" to the hobbyking uk warehouse so hopefully it will be in stock when i come to buy it. The shaft will be cut down from 24mm to 18mm which will make the motor 45mm high. Just going by the specs it seems like a hefty little motor, i'll be running the bar on a 2.5:1 reduction at 3s which will give it an overall theoretical speed of 5772rpm but with losses more like 5000 although i doubt i'll run it at full speed very often.
LYNX Beetleweight
 They do look good on paper but I have heard from several that the nanotech series' ratings are wildly over the truth. I think Gary used them last year in his feather and was disappointed. I have used the regular Turnigy packs (second hand!) but having never had them in a high power bot can't really comment on their performance. I can say confidently that they are batteries.
 The packs from Component-shop seem to be quite good, and although pricey Optipower are the real deal. You can get a roboteer's discount to soften the blow with them.
 Yeah i read Gary's report on the ones he used for his Boner (sorry) it may be that i buy ones with a larger C rating than woulod normally be required so even if it is bull it might still be enough. There's one i found with a 65 - 130c rating so i'll give it a go and see from there. This bot probably will be quite power hungry as i'll be running the blade and 4 gearmotors on the drive. If all else fails like you said the Optipower ones are the real deal and i should consider them an investment discount or not.
 I've been looking at drive motor options and just a quick question, obviously many people use the 1000rpm gearmotors from ebay and they're definitely an option but i seem to recall seeing a beetle fbs using four of these type of motors that i presume are usually used for antweights? http://www.ebay.co.uk/itm/2-Pin-Term...item2c725c215c just wondering how others feel about using them.
 I'd be interested to see how well the high power versions of those gearmotors from Pololu worked in a beetleweight, as they have far more power than an ant can actually put down. They're about 12W each peak, so I'd think 4 of them would happily power a beetle.
 Those ones on ebay are unlikely to be the high power version though, probably more likely the 4W version, which wouldn't be much use in a beetle I'd have thought.
 So Hatchet went to it's new owners today and i'm now left with just an empty cradle in my room where it used to sit. This has spurred me on to get something built so as of next month i will be buying parts to get the overhead done. I already have a shopping list so here's a quick run down, feel free to comment.
 2mm stainless steel baseplate roughly 180mm x 200mm
 10mm Hdpe chassis and structure
 This motor here to drive the blade http://www.hobbyking.com/hobbyking/s...tor_420w_.html
 4 of these for the drive http://www.ebay.co.uk/itm/12V-1000RP...item4d02e1d617
 2 Botbitz 10 amp escs's
 70 amp red brick esc to control the blade http://www.hobbyking.com/hobbyking/s...k_70A_ESC.html
 Possibly this Lipo http://www.hobbyking.com/hobbyking/s...dProduct=32243
 Buying this setup from Harry that he originally made for a beetle massacre.
 Let me know what you think, feel free to make any comments on areas you think could be improved.
 Not really an update but whilst on ebay last night I stumbled across a cheap link for the 1000 rpm motors, 2 for 6 pound is an absolute bargain http://m.ebay.co.uk/itm/390840968185?nav=SEARCH
