What size lipos are people running in beetles, I'm imagining about 1000mah but am not really sure?
Battery size
I'm planning on using a brushless like this to power my fbs:
http://www.hobbyking.com/hobbyking/s...Brushless.html
Is that about what others are using?
3 things about that motor.
1: it is a 380 size motor stuck in a 540 housing. This makes it running fast but it hasn't got much torque.
2: The bearing on the frontend of this motor sucks.
3: If you want to use this as a FBS power plant plan a good way to protect that 3mm axle or it will snap.
Ok, I've been looking at other motors as well but just wanted to check I was in the right range. I won't be connecting the shaft directly to the spinning element as it goes through a gear reduction of about 8:1. I'm planning to hav a ring running around the outside rather than a conventional fbs so that it is invertible, it just quite hard to get the power for the ring!!
I'm also planning a brushless drive but designing a single stage planetary gearbox to go on te end is also proving difficult due to the high rpm of smaller motors.
I've found all motors below 200g tend to only have a 5mm shaft. I wanted an 8mm shaft but all the motors I could find were very heavy and a bit pricey. I'm planning on mounting the disc directly onto the shaft, but I see a lot of replacement shafts being needed.
Well, yeah, that too. I want to try and avoid using pulleys/chains though, so I thought I'd try it this way first. And if my motor explodes on the first impact, I'll know its time to buy some pulleys. As for usable rpm, my kv is already quite small, so if I do end up with a pulley it'll probably be 1:1.
Anyway, we've drifted a bit off topic here... Is anyone planning on using anything bigger than a 1300mah?
