Thread
  • #61
    Re: Thread
    pugster, cover where the bar is connected and the shaft in araldite to prevent it coming off, also on the thread area so it doesn't un screw.
    • #62
      Re: Thread
      or just use the sensible, balanced discs that andy offered
      • #63
        Re: Thread
        the blade is welded on :shock:
        • #64
          Re: Thread
          anyway, what did you do to the servos again?
          • #65
            Re: Thread
            good!
            • #66
              Re: Thread
              i burnt them out because i didnt modify them right
              • #67
                Re: Thread
                what did you do to modify them?
                what voltage did you run them at?
                servos don't tend to smoke becuse of badd modding
                • #68
                  Re: Thread
                  what did you do to modify them i did not set the potentionmeter right?
                  what voltage did you run them at at 7.4v?
                  i think the reciver might have caused it because it didnt seem to work properly the light didnt come on and it didnt controll properly but when i used my ant weight reciver [wich is the same make reciver]it worked fine.
                  • #69
                    Re: Thread
                    Hay I just built this battle bristle bot
                    I built it on my own
                    • #70
                      Re: Thread
                      awesome
                      take us though exactly what you did when the servos blew up, what battery were you using?
                      • #71
                        Re: Thread
                        awesome
                        Lipos and it blew 3 servos
                        • #72
                          Re: Thread
                          thought so, it wasn't bad modding or the reciver the voltage was too high for them so they smoked.
                          dont plug lipos into the rx.
                          • #73
                            Re: Thread
                            How do you power them then if it's not plugged in to the rx
                            • #74
                              Re: Thread
                              you run it though an esc or votage regulator.
                              • #75
                                Re: Thread
                                Yay my 100th post new question what events are happening in febuary I have found out about 2 events but I can't go to ever of them any other events you no of.
