Thread
  • #31
    Re: Thread
    right, since your using lipos, you need some real saftey advice,
    you ask weather it will work with you ant charger, the awser NO! you antweight runs NiMH batterys this is a lipo, a much more volitle battery
    you need a lipo charger and charging bag. you also cannot have the battery in the robot to charge.
    be extremely careful, when lipos blow they blow big, youtube lipo fire to get what i mean.
    also i can't see a brushless esc in your cart?
    • #32
      Re: Thread
      That's powering the blade
      • #33
        Re: Thread
        i said that i didn't see a brushless esc in you cart.
        • #34
          Re: Thread
          Oh
          • #35
            Re: Thread
            It is at the top the red motor
            • #36
              Re: Thread
              He means a form of speed controller. You will need a separate, brushless speed controller to control your brushless motor.
              • #37
                Re: Thread
                What charger should I get then.can you give me a link to the charger I should get
                • #38
                  Re: Thread
                  You dont have to have a speed controller
                  • #39
                    Re: Thread
                    Originally posted by Pugster2002
                    Which way is a disk more effective vertical or horizontal
                    So which way is better vertical or horizontal
                    • #40
                      Re: Thread
                      You need a speed controler like this
                      http://www.giantcod.co.uk/hobbywing-pen ... -p-41.html
                      To power the brushless motor, and horizontal or vertical is up to you, horizontal means the chassis (frame) is smaller, and flatter, where as having it verticle is harder to make and mount, but has the advantage of being able to flip robots over also (if your having it spinning so it spins upwards)
                      • #41
                        Re: Thread
                        i recomend the pro peak quattro plus charger, never let me down.
                        • #42
                          Re: Thread
                          that would be the cheapest decent charger.
                          • #43
                            Re: Thread
                            where can i get it
                            • #44
                              Re: Thread
                              The parts have arrived
                              • #45
                                Re: Thread
                                my mum through away the controller for my robot riot it will never work now
