is a beetleweight worth building?
  • is a beetleweight worth building?
    who actually builds and competes them?
    and wht sort of weapons?
    Re: is a beetleweight worth building?
    There's no official competitions yet, as there is no arena, but theres a few beetles, I have a drum bot (but I need to re build the chassis as its to heavy) and I have the body of a flipper, but no pneumatics yet, and I know there's quiet a few out there like 180, and stuff, I think if arena is built, this would be a very popular weight class, as there quiet easy and cheap to make
      Originally posted by JED1999
      Who actually builds and competes with them?
      And what sort of weapons are there?
      1) As far as I know a full combat arena is being made. And I think there are a few bw's knocking about. Someone made a small rep of 360. Which in turn is a rep of hypno disc. And IIRC K_c_r is making a rep of Pussycat.
      2) Presuming that this arena is built, then spinners should be fair game on this one. I think an active weapon rule was discussed some time ago.
        someone should set up a beetle weight competion,
        anyone got the rules set for beetles?
          yes there are rules
          the arena is being built
            Problem is the active weapons, so you really need an arena to run them, can't really just take them along to events and have a go between shows or anything as the vast majority of them at the moment seem to be spinners.
              what is the size limits
              and weight
              also what is size of arena?
                Look at the topic directly below this one, first post....
                  dosent tell you size limits!
                    thats beucse there are none
                      Ive built one and it has a blade
                        I do I have made 3 beetle weights smiley riot and battle rage and there all spinners
                          Not really
                            No
                              Who is building this arena?
