Help im sooooooooooo confused
This topic is closed.
    You basically need 1 channel for each servo, so basically, a ant with 2 wheel drive (2 servos) and a weapon (1 servo) would need a 3 channel R/C set.
    Have a look at the ant shop and forum at http://www.robotwars101.orgwww.robotwars101.org
    Mike
    http://www.bobblebot.co.ukhttp://www.bobblebot.co.uk
      he said there out of stock
        http://www2.towerhobbies.com/cgi-bin/wt ... 6012**&P=1
        how does this type of control drive? are all drives controlled by the 1 joystick?
          It says This stock number is invalid:
          Mike
            paste it into ur adress bar
              I did other wise it wouldnt of worked at all.
              EDIT never mind it works now.
                Yes I think that 2 servos would all be on 1 stick but I dont think it is legal to use a 72mhz frequency in the UK for a ground vehcle. I think it has to be 40mhz or 27mhz.
                Mike
                • #23
                  im lookin at these 2
                  http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LC6056http://www2.towerhobbies.com/cgi-bin...I=LC6056**&P=1
                  youll gave to paste it into ur adress bar again
                  • #24
                    Both of those links seem to go to the same place, but the product looks fine and I think it is the one I use. Although if you need to buy in the UK it is an American site.
                    Mike
                    • #25
                      http://www.train-and-track.co.uk/control/radio/radio.htmhttp://www.train-and-track.co.uk/con...adio/radio.htm
                      i found it on a english site
                      would the servos that come with it be good enough or would they need replacing?
                      • #26
                        The servos would be fine, but I belive they weigh 43g which is way to heavy for an Antweight.
                        Generally you do not want servos heavier than about 25g.
                        Mike
                        • #27
                          ok thanks
                          ive got a good idea of what to do now
                          if the weapon is a spinner, it just needs annother servo to spin it, but wot about an ax or flipper?
                          • #28
                            If it is a spinner then you will need a motor to spin it as a servo will not be powerful or fast enough (although for your first ant, I do not recommend building a spinner).
                            If you want an axe or flipper then an unmodified servo attached to the arm of the axe/flipper will do just fine. You could try pneumatics, but for your first ant again, I dont recommend it.
                            Dont forget that normal servos do not spin through 360 degrees so you will need to modify them to use for the drive of your ant.
                            Mike
                            • #29
                              thanx alot guys ill keep ya posted how its comin along
                              • #30
                                No problem If you need anymore help, here are some useful sites to have a look at:
                                http://www.robotwars101.org/antshttp://www.robotwars101.org/ants
                                http://www.antweight.co.ukhttp://www.antweight.co.uk
                                http://www.bobblebot.co.uk/antweightshttp://www.bobblebot.co.uk/antweights
                                http://www.antweight.comhttp://www.antweight.com
