alumide on shapeways
    Re: alumide on shapeways
    Aluminium is not 44 grams cm3 it's a 10th of that, about 4 grams cm3
      really?
      that's nothing
      time to make bot bigger
        alu is too soft for discs tbh
          like 1cm thick is enough.
          anyone ever had bad experience with aluminum in discs
            at 10mm thick you *should* be okay. 2mm ti would be better tho
              Remember, 3D printing is adding material, Milling is removing material.
              I think this is one of the main reasons anything that is 3D printed ends up being quite brittle.
              I think for the sake of a spinning weapon on an Ant you could just shape some thin Ti sheet. Can easily hacksaw through 2mm, and although it'll take some elbow grease you can file it into shape and drill it.
                I got loads of ti from hazard2.
                to make it wider could I have a ti and aluminum sandwitch
                can you harden materials like aluminum?
                • #23
                  The idea of 3D printing in metal is really appealing, but found this disclaimer on the Shapeways website, so I doubt it would be up to robot combat.
                  Please note that the materials we use for manufacturing the products make the products suitable for decorative purposes and they are not suited for any other purpose . .
                  It might be useful for a chassis but probably not a spinning weapon.
                  • #24
                    Oh yeh, chassis only most definitely.
                    Alumide is 1.35 g/cm cubed by the way.
                    • #25
                      finally cheers everyone
                      • #26
                        PS that's as light as polycarbonate is it weaker than that?
                        • #27
                          PolyCarb is 1.36g/cm, so lighter!
                          I don't really know anything about Alumide, but Polycarbonate has an incredibly high impact toughness (much higher than that of HDPE) but has it's flaws.
                          I'd say give it a try!
                          • #28
                            polycarbonate/alumide
                            is 4-6mn polycarb enough?
                            • #29
                              4mm-6mm polycarbonate is fine for amour, just not alll around
