what should i use to cut polycarb for myant weight
polycarb :)
Re: polycarb
We use a jigsaw with blades like below for Mutes poly but its 12mm thick so hacksaw would be fine
http://www.screwfix.com/p/multipurpo...ack-of-3/21572
Re: polycarb
For the 1mm poly i used on my ants i either just cut it with a pair of scissors or used a sharp modelling knife and cut a straight line in it with a ruler and then bent it, that way it broke along the line making it straight.
It's easy enough bending polycarb to the shape you want and screw it together
Polycarb does shatter if you hit it hard enough. With the forces unleashed by the spinners in a antweight arena I wouldn't be surprised if it was polycarb. They way to tell the difference it to look along the side of the sheet. Acrylic looks white where as polycarb looks a dark grey to black. It doesn't matter how it was cut it will be this colour regardless.Last edited by Eventorizon; 20 April 2014, 10:28.
