metal milling
  • metal milling
    Hi
    Can anyone make me a robot out of about 1mm aluminium?
    Thanks
    Re: metal milling
    alu is rubbish for ants, dont bother.
      Re: metal milling
      Titanium is too heavy even though Its really light My robot hazard 2 (see it on build diary) has some 0.5mm armour made of ti and its 50grams!
      Could you get it hardened?
      Then it would be strong
        Re: metal milling
        use plastic, much better
          Re: metal milling
          What thickness
          will 2mm hdpe be spinner resistant
          (for a bit anyway)
            Re: metal milling
            i use 6mm hdpe sides, with a 0.5mm ti scoop, nothing has got though that.
              Re: metal milling
              bwaahhh
              thats like 5kg
                Re: metal milling
                not really
                harry has it proved against complexity?
                  Re: metal milling
                  yeah
                  for a spinner the disc would be aluminium/titanium
                  The armour-about 3/4mm HDPE depends how much weight
                    Re: metal milling
                    not had the pleasure of fighting complexity but i have faced most of Mr wallers creations and not taken much damage, interta took chunks out but didn't penatrate.
                      Re: metal milling
                      Oh s peter waller owns complexity
                      (thats the one time you can look at me like a noob-as far as my signature goes)
                        Re: metal milling
                        no, Josh Valman owns complexity.
                          Re: metal milling
                          oh well the spinner setup im thinking of is 75grams so thats 75 grams for armour and a disc
                          not bad
                          New subject-can anyone print plastic?
                            Re: metal milling
                            shapeways will 3d print a shell.
                            75g incluing disc right?
                              Re: metal milling
                              yep
                              7g speedo
                              19g motor
                              18g of servos
                              8g reciever
                              Not sure about lipos
