Speed control
  • Speed control
    Can any one name a servo board that won't brake over time when used with a 6.0 volt battery and is not as big as the board in a s3003 servo
    Re: Speed control
    http://www.giantcod.co.uk/sg5010-towerp ... p-205.html
    have used these in ants on 6v with much success and they're still going even work on 7.2v
      Re: Speed control
      they are a bit weird though. why not s3003?
        Re: Speed control
        yeh but only £4
          Re: Speed control
          s3003s £3 delivered
            Re: Speed control
            still waiting for a link on that
              Re: Speed control
              Well in my ant most of the space is taken up with the axe and scoop so theres really not enough space for 3-servo boards of that size
                Re: Speed control
                you could buy the planet 5 rx/speed controller of archie and use a s3003 for the axe, alternatively you could looking into using a scorpion mini for the axe if you're still pushed for space
                  Re: Speed control
                  how is there not space mate? the servo boards are about a cm by a cm, not including leads. they will fit fine
                    Re: Speed control
                    not this one its 4cm by 2cm
                      Re: Speed control
                      oh, iknow those boards, get some hitecs then, they are not like that
