Spinner motors
  • Spinner motors
    ive heard that slot car motors can be used as antweight spinner weapon motors.
    is this true? and what sort of voltage, speed, torque am i looking at in a typical slot car motor.
    Spinner motors
    yes it can be used.
    http://www.antweight.com/links.htmlhttp://www.antweight.com/links.html
    there is a link to a good one (stinger) if you scroll down a bit. I will leave it to the spinner guys to give you some better info.
      Spinner motors
      I normally use the Ninco Stinger MilitANT, CombatANT, ANTicyclone.
      voltage 12v
      speed 31000rpm
      current 320ma
      torque 226gms/cms
      weight 24gms
      supplier pendelslotracing.co.uk
        Spinner motors
        how about one of these? http://www.sussex-model-centre.co.uk/item.asp?ID=2572http://www.sussex-model-centre.co.uk/item.asp?ID=2572
          Spinner motors
          400-700 gram?
          for an ant?
            Spinner motors
            its weighs 43g
            but you need the proper controller bit slow for brushless there are better out there
              Spinner motors
              I have just got a brushless motor from the USA that does 65000 revs per minute at 12V. I have no way to verify this but it really does sound fast. Now all I need is a disc balanced enough to run at that speed.
                Spinner motors
                Are you about to run an ant on 12V?
                  Spinner motors
                  Thats not unusual Danny.
                  Pete, I think it might be worth constructing a dynamic balancer- there are some good plans around on the web, most seem to be an attachment built to be used on the lathe bed- model gas turbine sites are probably a good place to look.
                  I was considereing getting back into ants (I havnt built anything since WS4) but Im not so sure I will now :-p
                    Spinner motors
                    Aha okey, can the reciever and servos handle that current or ist there a seperate battery for the reciever?
                      Spinner motors
                      Most ants that use 12v (12.6v if you want to be accurate, 3 x Lithium polymer cells) are spinners, and as such have a ESC for the weapon motor, this normally has a voltage regulator onboard, which you then use to power your reciever and drive servos. If you want to run more than about 6v in an ant without an ESC, then you simply take 2 lines off the battery, one of which goes directly to whatever it is youre running at the higher voltage, the other of which goes through a 5/6v regulator to the RX and other servos.
                        Spinner motors
                        I see
                          Spinner motors
                          Some servos can supposeldy take it, usually the larger ones. The micro servos get upset above 6V really. Some have had success at 7.2V. It all seems a bit hit and miss really, but yes, the rest of the ant is run off the BEC
                            Spinner motors
                            Eddy that sounds like a good idea. I have a static prop balancer which has been good enough up to now (max 35000 rpm) but if I do get vibration problems I might just look into that.
                              Spinner motors
                              yay my stinger arrived today
                              nice pic of it sitting on the new ant (wheels are just there to give and impression)
                              http://s4.invisionfree.com/Antweight_Forum/index.php?showtopic=66&st=0&http://s4.invisionfree.com/Antweight...topic=66&st=0&
