I need to buy a good battery and I have my eyes set on the one used in ant awe 6, I am looking for that battery and a charger for it.
The battery used in ant awe 6
Re: The battery used in ant awe 6
Hi,
I built Ant Awe 6 and it uses a 180mAh, 2 cell Lipo. I got mine from http://www.micronradiocontrol.co.uk but they don't seem to have the exact one which I use any more but this is the nearest one to it which they sell. http://micronradiocontrol.co.uk/lipo_efl.html (the second one)
As for the charger I use the Blue Arrow 2S/3S LiPo Charger (150mA - 550mA) which can be found here http://micronradiocontrol.co.uk/charger.html
Hope this helps
Thanks for that I have now found with that info a similar lipo
2 question
Last time I use a duracell 9v battery and I had to build a power supply for it
will I have to with 7.4v
Will this charger do for it
http://www.art-tech.com/english/Article ... icleID=163
http://www.rcgraveyard.co.uk/losi-micro ... s-94-p.asp
Slight issue is that charger has a MINIUM setting to charge at 0.3A (300mA), which is too high for your 180mA lipos. No battery should ever be charged at over their capacity rating.
I would personally recommend a Pro Peak Quattro Plus. I've been using the original for 4 years now, never have a problem. The plus has the advantage because it has a built in mains plug, mine has a seperate 12v power supply.
BTW, when you said you had to build a power supply for a 9V battery, I'm not sure I follow.
The problem for me is I don't have enough money for a fancy charger I just ask that anyone could give me suggestions as to the cheapest charger for that battery please. Would this do http://micronradiocontrol.co.uk/charger.html the blue arrow charger on this page and does it connect to a wall socket. Help would be great.
I am envious of your generosity but I have my mind set on buying the pro peak plus charger. However I am confused because I am not sure wether it will charge this http://www.rcgraveyard.co.uk/losi-micro ... s-94-p.asp and and if it has a wall plug.
