servos
  • servos
    i want to build a ant weight robot and i want to keep it cheap so i was thinking 2 modded 360 servos for drive a receiver and a battrey any help?
    Re: servos
    yes that would work but dont expect it to win any thing i did that at the start but i have now moved on to bigger and better things.
    cheapest servos(good speed bad torque) easy to speed hack
    http://www.giantcod.co.uk/towerpro-s...rvo-p-268.html
    batterys
    http://www.component-shop.co.uk/
    i used both for a while
    this is a forum which is more for antweigts which may be helpful
    http://www.robotwars101.org/phpBB/index.php
      Re: servos
      do i have to use servos or can i plug a motor in the recever?
        Re: servos
        a motor needs a speed controler which plugs into the reiver, its is much more expensive but nearly all ants use it. speed contollers are about £45
          Re: servos
          Servo robot at http://windisch.co.uk/robots/howto/build_a_robot.htm
          Motor robot at http://www.antweightrobots.com/kitty/index.htm
          You might also want to try http://www.robotwars101.org/phpBB/ for antweight questions.
            Re: servos
            IVE GOT THE SMALL SERVOS FROM GIANT COD £5 FOR 2
              Re: servos
              ps not reccommended
                Re: servos
                whats not recomended?
                  Re: servos
                  his cheap servos I think he means
                    Re: servos
                    very much recomented by me though
                      Re: servos
                      can u take the gears off and use the servo motor?
                        Re: servos
                        no, that would mean your robot would not move, the motor on its own will have no where near enough torque to move a robot, they are good speed hacked though
                          Re: servos
                          Until they both fail on the day of the event
                            Re: servos
                            sd200's all the way, outpushed dynamite at the latest AWS and thats one of the torquiest robots around
                            at £12 each there pretty cheap too, a bit more pricy than the budget servos but will last for donkeys years
                            Jack
