What 2.4GHZ trans set would you recommend for a beginner?
  • What 2.4GHZ trans set would you recommend for a beginner?
    That's got to be the most expensive part, but I definitely want to be going for 2.4GHZ.
    I've been having a look at Bobblebots FAQ and they recommend these 3 in particular:
    * Spektrum RC DX6i/DX7 range
    * Planet 5 2.4Ghz Set
    * Radio Link 2.4 GHz Set
    The last one is the cheapest (£26!), but it has been said that it's better to buy an expensive one now that will do everything I need it to, and last, rather than having to keep buying cheap ones and rack up costs over time. Still, hundreds of quid is a bit much, as the most expensive one.
    What would you recommend for the best balance of cost, reliability, and function in a 2.4GHZ, 4 channel transmitter/micro receiver? Any of those, or something else?
    Ideally, the £26 model would be good enough. I can't be sure though, until I get more recommends, and it needs to have a micro receiver and have fail safe operation, of course.
    Re: What 2.4GHZ trans set would you recommend for a beginner
    I would go for the Planet 5 personally, as if you get one of those and you ask Peter Waller on the antweight forum very very nicely, he will be able to turn your reciever - in a manner reminiscent of Kurt and his Apricorns from the Pokemon games - into a combined reciever and speed controller for a very good price.
    I have a DX7 but that is a bit excessive, and half the switches have fallen off since I got it, hehe...
      I have the Planet 5 for my FW, and it's been very good so far. The receiver is absolutely tiny. I can't really recommend anything since I don't have any experience with the others, I just know the Planet 5 is great for me.
        i've had no experience with planet 5 but i would stay away from giant cod. i've had lots of problems with it and now have upgraded to dx6i. i'd recommend buying a dx5e off team hydra (assuming they still have one left) and using one of these receivers:
        http://www.hobbyking.com/hobbyking/stor ... duct=12586
        my mate uses them with his dx5e and they work fine, also work fine on my dx6i
          I suggest the Planet 5, has five channels and a very nice compact reciever. I bought mine at a local model shop for £50. I think it has no crystal though and only works with the reciever it came with.
            2.4ghz needs no crystals. they just work with whatever receiver they're bound to
              Stagfish: The DX5e will work with a lot more than the AR500 they come with, , AR6300, AR6100, etc, they all work with it.
              As for a suggestion for a starter 2.4GHz set, I would suggest a Planet 5 for an antweight, because of the lightness of the receiver, but there is nothing wrong with the Radio Link set, I am using them for the K*bot Division 3 units, works fine for a long range, longer than you'll need for a robot.
                i agree, incorporating a large 12g receiver into a fleaweight is hard.
                  Sounds like the Planet 5 would be best then. Thanks, guys.
                    I apologise to Stagfish, I misread his post as a DX5 not a planet 5, my bad :P
                      Apology accepted :wink:
                      The strange thing about the planet 5 though is that the controller has five channels, while the reciever has seven. Is there any reason to this?
                        One of the extras is likely to be a battery port, the other, maybe a secodary elevator port like the AR500 has, I'll check the picture
                          Its not the battery port, it has seven channels. I can post a picture if you like.
                            What cheap high torque servos would you guys recommend? For my first antweight, I'm going to go for something simple - a pushbot with lifting spikes.
                            So far, for my shopping list I just have:
                            - Planet 5 trans/rec set
                            - HDPE
                            Anything else I need apart from the servos? I have some mini go cart wheels years ago from lego mindstorms somewhere, but I can't remember if they would be the right scale, or give good traction.
                              The Park HPXF tends to be quite good...most powerful, pushy ants these days use motors though, Pololu 50:1 HP gearmotors are what I use on Jigsaw and a few other people use on their ants for maximum torque.
