I'm curious could you build an antweight full body spinner The concept is there and I think it is plausable, How would I go about making the shell? a small wheel hub maybe bellow the 4 inch diameter?
Antweight Full Body Spinner
Re: Antweight Full Body Spinner
It has been done before:
http://www.antweight.co.uk/results/ws22 ... CF1757.jpg - MBY
http://www.antweight.co.uk/results/ws22 ... CF1773.jpg - Anticyclone
http://www.antweight.co.uk/results/ws30 ... CF6842.jpg - Desire
They tend to use custom milled shells, usually ali, although for Anticyclone I believe Peter Waller used an ashtray or something similar :P The problem with antweight full body spinners is that they really aren't too effective, as the low weight physics of horizontal spinners in general is against them (when a 150g/225g robot hits another one with a third of its weight in the spinning weapon, both are going to go flying very far with the energy involved) and in order to get a good shell and a good drive for the weapon into the weight and size limit you often need to compromise on drive (or maneuvrability if you make it a walker)
