AW Rules
  • AW Rules
    Hi everyone, I'm new
    I've joined the forum with the intention (and hopefully capacity) to build a robot or 2 and join in some events.
    I've been looking into it and have decided to attend a few events first and to start small, unfortunately there isn't any events around Yorkshire as yet so I'm inevitably fiddling with remote control stuff in the mean time...
    And anyway, my first question... Do all the rules in the 2008 Build rules pdf apply to ant weight as much as any other category? I mean it seems unusual to have fail-safes and power lights for rc robots smaller and less dangerous than the average kids rc car...
    Thanks :wink:
    Re: AW Rules
    Hiya, welcome to this sport of ours
    The antweights, by and large, tend to operate seperately from the rest of the FRA - http://www.robotwars101.org/ is the main site with an active forum where ant builders congregate, and the current incarnation of the ant rules can be found at http://www.antweight.co.uk/rules.htm .
    Hope that helps
      Re: AW Rules
      Failsafes may seem silly but something like an antweight spinner could probably see of to that thumb you've been saving for your entire life. They aren't complicated or difficult to meet so it is just easier to abide by them!
        Re: AW Rules
        Hiya, and welcome to this wonderful hobby
        Antweights don't reqire failsafes on the drive, since they are nice and light, but do require one for the weapon, because ant weapons are generally made of metal, and can do you an injury if they go spaz.
        For more info on Antweights, the forum Joey linked to is the best place to get advice on the subject.
        As for events in Yorkshire, there have been and will be in the future, ants are welcome at Roaming Robots and Robot's Live events (dunno about Robochallenge, never thought to ask :P), there may well be an AWS coming up next year in Yorkshire...
          Re: AW Rules
          I've never had any real issues with travelling down from Yorkshire to events, it does mean a few early mornings and a lot of train tickets but you can get to just about anywhere that hosts events from Wakefield Westgate station in my experience.
          (I am also rather insane)
            Re: AW Rules
            Thanks for the replies and the welcome :wink:
            I've been doing a little research and fiddling around with a couple of rc toys, and as always when trying to enlighten myself I have more questions:
            I've discovered i have a system set out already, an old rc hovercraft with a button for the motor that controls the lift, ie a failsafe, it's a constantly running motor which would lend itself to a spinny thing of some kind. Only I think there might be one or two problems; if it goes out of range the switch wouldn't turn off the motor, would that matter since it's not likely to get far out of range?
            The battery atm is heavier than the whole robot is allowed to be so where might i find batteries suitable for an AW? Ie about 9.6V ish, light and not containing liquid acids or anything else disallowed...
            3rd possible problem... I have no idea how to change or even where to locate the crystal to change the frequency, it say's it's 27MHz though
            and again, thanks
              Re: AW Rules
              I would travel to further events if I wanted but I don't fancy paying for the diesel! yeah yeah, yorkshire short arms de.....
              I can wait though
                Re: AW Rules
                No problem David
                R/C toys might not have a facility to change crystal, given that they're produced very cheaply using pretty much the minimum parts needed to get them working. You'd be better off investing in some proper R/C equipment really, that's the sad truth :P it needn't cost much, I got my first set of 40mhz gear for £50 and it's served me well and you can get 2.4ghz sets for under that price now.
                Also an on/off button on a transmitter doesn't really count as a failsafe, the entire point of a failsafe is that it shuts the weapon down when signal is lost/the robot goes out of range, so that idea is a non-starter I'm afraid. The vast majority of speed controllers available for antweights at the moment do failsafe though, along with some of the more spohisticated R/C systems, so separate failsafes aren't likely to be an issue.
                Most good antweights (and a few really bad ones too) use either 7.4v or 11.1v lithium polymer batteries, they can be bought from most R/C model shops. The supplier I usually use is Micron Radio Control as they've always been really good with service and delivery...Lipos do require special charging gear and can be dangerous though, if you're looking for something safer and less complex you can get 4.8v and 6v NiMh packs from Technobots, or in a pinch run the robot from a PPV 9V battery.
                  Re: AW Rules
                  No problem David
                  and yet spall managed to survive
                  http://www.youtube.com/watch?v=EPTQnG-yCdI
                    Re: AW Rules
                    Aparently it is possible to change the frequency of rc toys if they're close enough
                    http://www.instructables.com/id/Modd...ior-Fernlenkf/
                      Re: AW Rules
                      Spall did have a frequency change of sorts, I suspect that's what the extra switch on the controller is for. (in any case, it was infrared :P)
                        Re: AW Rules
                        No problem David
                        R/C toys might not have a facility to change crystal...
                        Right then, More questions!
                        I've been tinkering with old stuff again, are you allowed to use a part of rc stuff, I have an old tank within dimensions and weight limits, all I'd be using is the motors, chassis and tracks, the rest would be home built, ie remote control system, battery, armour and all the rest that is needed, which raises a noob point which proves how far I have to go to understand everything...........
                        What parts are 'needed'? There's obviously motors, transmitter, receiver, battery, something to move it along (wheels / tracks / legs) but what about speed controllers? are they necessary and what exactly do they do? Is there anything I've missed...
                        Also, after looking around parts websites, how does the signal from a receiver translate into motors moving? Do they have connections straight to motors or is there a step in between?
                        And finally a cheeky one, could someone give me an example of a receiver that is suitable for AW; light, small, etc... that would run on a 9V battery? I've decided it's the simplest and most readily available battery...
                        I think I'll leave the other forum for now, one is enough methinks, plus this way I get to hassle you lot some more
                          Re: AW Rules
                          Originally posted by sabotageDave
                          ...what about speed controllers? are they necessary and what exactly do they do? Is there anything I've missed...
                          ...how does the signal from a receiver translate into motors moving? Do they have connections straight to motors or is there a step in between?
                          ...you answer your own question there virtually :P The speed controller is what goes between the reciever and the motors to get the motors moving, and it's also what batteries generally plug into - most speed controllers can power the reciever from a regulated supply from the battery.
                          An absolutely brilliant guide by Andy Hibberd (five time AWS champion including three consecutive wins...grr...lucky fecker...:P) to wiring antweights with diagrams can be found here: http://www.robotwars101.org/phpBB/viewtopic.php?t=1399 and illustrates how on a budget you can also use modified servos to get a robot going.
                          You would be allowed to use the drive and other bits from R/C tanks; it's just the radio gear that's suspect (and often the control circuitry is part of that so needs to be replaced too). Recievers needn't run straight off 9V batteries as you can run them through regulators (either on the speed controller board or standalone ones) so they only get 5V and don't fry themselves, so you can use pretty much any sub-10g reciever that's compatible with your chosen transmitter.
                            Re: AW Rules
                            Right, I'm learning, the questions are getting more focused
                            I have a couple of examples but have no idea if they're compatible:
                            Speed controller: http://www.technobotsonline.com/saberto ... oller.html
                            Receiver: http://www.technobotsonline.com/futaba- ... -4-ch.html
                            I'd guess they are compatible, I have a feeling I'm going to be asking questions every step of the way here...
                            I also am having trouble finding a transmitter with a skid steer layout, All the online shops I find only have Forward-Back, Side to side controls or the wrong frequency.
                            That guide is very useful btw :wink:
                            tia
                              Re: AW Rules
                              I know its unavailable ATM, but http://www.technobotsonline.com/saberto ... 30698.html is the same as you linked to, but it has the RC wires already attched, so no mucking about doing it yourself.
                              The RX and sabretooth are compatible, in fact I use both in my drive-all-day ant, Bulletproof.
                              As for skid steer, not quite sure what you mean, what do you want the robot to drive like?
